Ceramic tile installation tips - Renovations using Ceramic tile or Stone
Maximum Span Calculator for Joists
Sponsored Links
Post Your Photos!
bamboo porcelain
travertine shower w/ glass mosaic inlay
final pics of marble shower and bath
Marble shower/bath
Heated floor in a steam shower
Search
Topic Options
#15459 - 02/18/10 11:58 AM reducing overall stack of underlayment
Mojambo Offline
New Member
Loc: ottawa, canada
Hi,
I'm looking for advice on getting the proper product for the underlayment on my main floor.
We are replacing approx. 1000sq. ft of existing tile. The current installation is 12x12 porcelain tile on 1/2" plywood underlayment, over 5/8 T&G OSB subfloor. the subfloor is glued and screwed(I can see the glue from the basement)
Joists are solid pine, 2x10, 16" O.C., 13' max span. the house was built in 1996 in Ottawa, Ontario, Canada
The current installation has failed at multiple places where large cracks across multiple tiles are seen. no new cracks have former over the years, but these cracks have been there as long as I remember(7 years) Of course the grout is cracking at multiple places as well.
Now we are at the point where we are going to replace the entire floor. This floor goes into the kitchen, hallway, mudroom/laundry room, front entrance/foyer.
The installer advised he would use 1/2" ply over the OSB, but hasn't looked at the specific details I know to look for. He stated he would use whatever products I wanted. Now I know from reading this site, it all depends on the type of tile being used.
We have not chosen the tile yet, but we'll say stone as I think it would need the most re-enforcement.
I'm trying to avoid increasing the overall height of the floor.
Rather than 1/2" ply, ditra, thinset, tile, I remember reading about a plywood that is 3/8" or 3/16" but is as strong as 1/2".
This would allow the overall height to be reduced or not increased by a large amount.
Can anyone advise what this special underlayment is? I searched and came up with Halex 3/8"m but it stated that it is only to replace 3/8" and is not suitable for 1/2" substitution.
Any help is appreciated
Thanks
Eric
Top
#15463 - 02/19/10 01:31 PM Re: reducing overall stack of underlayment [Re: Mojambo]
RobertTiles Offline
Member
Loc: Edmonton, Alberta
Hi Eric,
I'm sure the regular members will be able to provide you with plenty of advice. Have you read information regarding "movement joints"? Sounds like you have a multiple room installation. The lack of movement joints in your current tiled floor might be the reason for the cracks. Movement joints will be something you will want to consider before installing your new tiles.
Top
#15466 - 02/19/10 04:36 PM Re: reducing overall stack of underlayment [Re: RobertTiles]
Mojambo Offline
New Member
Loc: ottawa, canada
I'll look into the movement joints. I def. do not have any in the current installation. I imagine the movement joints are put in at the room to room thresholds(doorways)
I'll search this some more and post up a floor plan for you guys to look at.
Thanks
Eric
Top
#15529 - 02/25/10 11:13 PM Re: reducing overall stack of underlayment [Re: Mojambo]
Jaz Offline
Senior Member
Loc: Troy, Michigan U.S.A.
Hi Eric,
There may be several reasons your installation failed. Some could be the lack of expansion joints both in the field and at the perimeter at all walls. I think the biggest problem likely is the installation direct over plywood though.
The birch plywood Harry (the owner here) referred to in the past was indeed Halex. I've seen it, but never used it. The plywood thickness for your floor may depend on whether you go with porcelain or stone. Actually I'd go with min. 1/2" but think 5/8" is more like it. Your 5/8" OSB subfloor is really an inferior product, love those cheap ass builders.
But again go with as much plywood as possible. Since you're gonna use Ditra you'll be saving some height there over 1/4" CBU's.
You should also check your joists to be sure you don't have too much deflection. Use the "Maximum Span Calculator" above left. You need no more deflection than L360 for ceramic or porcelain and L720 for stone tiles. (lower numbers = more deflection).
Jaz
_________________________
Tile 4 You..Troy,Michigan U.S.A.
www.tile4you.com
KERDI Shower Specialist-DITRA Installs-Containers of TRAVERTINE direct, ship anywhere. SAVE 40-70%
I've NEVER made a mistake, I thought I did once...but I was wrong!
Top
#15559 - 03/04/10 04:15 PM Re: reducing overall stack of underlayment [Re: Jaz]
Mojambo Offline
New Member
Loc: ottawa, canada
Thanks Jaz,
I ordered the Halex in 3/8". not too cheap either. it works out to approx. $2 a sq/ft.
I'm not installing stone for sure. We will install porcelain or ceramic.
My deflecto comes out to L/458. so stone is out of the question.
I can't believe the builder cheaped out on OSB. This is an expensive custom home.(I wasn't the original owner). I can't lift the entire floor. Too much involved.
At this point I feel very confident that this 3/8" halex, Ditra combo will be more than enough for a proper long lasting tile installation.
Thanks again for all the help,
Eric
Top
February
Su M Tu W Th F Sa
1 2 3 4
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29
Newest Members
abelabbey26, kuro, Deadeye, Murphy, dukefan3414
3387 Registered Users
(Views)Popular Topics
Where do I begin... 51078
Kerdi Board 32934
Installing Nu Heat on Cement Slab 22821
Kerdi over Denshield 18647
Help with preslope!! 17328
Self-leveling compound on plywood 15616
slate tile on heated floor 14055
best liquid waterproofing? 13201
Ted's Shower 12250
tiling around shower drain in conrete basement 11387
Forum Stats
3387 Members
16 Forums
3472 Topics
Max Online: 505 @ 02/07/12 09:26 PM
Who's Online
5 registered (kuro, abelabbey26, pmacaula, Deadeye, 1 invisible), 370 Guests and 8 Spiders online.
Key: Admin, Global Mod, Mod
RSS Feed
Subscribe to our RSS Feed
Home    Forum     Technical Info     Our Service     Photo Gallery     Installation    Contact Us    Privacy     Links    Books
