Ceramic tile installation tips - Renovations using Ceramic tile or Stone
Maximum Span Calculator for Joists
Sponsored Links
Post Your Photos!
bamboo porcelain
travertine shower w/ glass mosaic inlay
final pics of marble shower and bath
Marble shower/bath
Heated floor in a steam shower
Search
Topic Options
#15596 - 03/10/10 05:51 PM pre-pan pitch
Thor Offline
New Member
the distances from the walls to the drain range from 5'(furthest point)on the west wall to 2'(closest point) on the remaining walls. Going by the 1/4" per foot rule how do I keep the north and south wall corner lines level? If I keep the corner lines level will the pitch be too much where the drain is closest to the walls
Top
#15597 - 03/10/10 09:42 PM Re: pre-pan pitch [Re: Thor]
Kman Offline
Senior Member
Loc: Pea Ridge, Arkansas
That's usually how it works out. If you've got 1/4" per foot going to the furthest wall, you'll have a little steeper slope on the shorter runs in order to keep the perimeter height level all the way around.
_________________________
The top ten reasons to procrastinate:
1.
Top
#15599 - 03/10/10 10:04 PM Re: pre-pan pitch [Re: Kman]
Jaz Offline
Senior Member
Loc: Troy, Michigan U.S.A.
That's the reason the drain should be as close to the center as possible.
Also remember to measure from the drain to the corner not the middle of the wall. The corner is usually a good 6" further yet. Also remember the 1/4" per ft. is the recommended min., you could make it 3/8" instead.
Jaz
Tile 4 You..Troy,Michigan U.S.A.
www.tile4you.com
KERDI Shower Specialist-DITRA Installs-Containers of TRAVERTINE direct, ship anywhere. SAVE 40-70%
I've NEVER made a mistake, I thought I did once...but I was wrong!
Top
#15600 - 03/11/10 03:27 AM Re: pre-pan pitch [Re: Jaz]
Kman Offline
Senior Member
Good points, Jaz. You should always measure to the furthest corner.
And I always set the pitch for floors at 3/8" per running foot.
1.
Top
#15604 - 03/11/10 08:59 AM Re: pre-pan pitch [Re: Kman]
Thor Offline
New Member
Thanks guys, I can now proceed.
Top
February
Su M Tu W Th F Sa
1 2 3 4
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29
Newest Members
abelabbey26, kuro, Deadeye, Murphy, dukefan3414
3387 Registered Users
(Views)Popular Topics
Where do I begin... 51078
Kerdi Board 32934
Installing Nu Heat on Cement Slab 22821
Kerdi over Denshield 18647
Help with preslope!! 17328
Self-leveling compound on plywood 15616
slate tile on heated floor 14055
best liquid waterproofing? 13201
Ted's Shower 12250
tiling around shower drain in conrete basement 11387
Forum Stats
3387 Members
16 Forums
3472 Topics
Max Online: 505 @ 02/07/12 09:26 PM
Who's Online
5 registered (kuro, abelabbey26, pmacaula, Deadeye, 1 invisible), 370 Guests and 8 Spiders online.
Key: Admin, Global Mod, Mod
RSS Feed
Subscribe to our RSS Feed
Home    Forum     Technical Info     Our Service     Photo Gallery     Installation    Contact Us    Privacy     Links    Books
