Ceramic tile installation tips - Renovations using Ceramic tile or Stone
Maximum Span Calculator for Joists
Sponsored Links
Post Your Photos!
Volcano Travertine Walk-in Shower with Glass Block
bamboo porcelain
travertine shower w/ glass mosaic inlay
final pics of marble shower and bath
Marble shower/bath
Search
Topic Options
#17571 - 02/09/12 03:46 PM Tile backsplash over brick/concrete
pmacaula Offline
New Member
Loc: Toronto
I have just stripped a kitchen down to bare walls & replaced the damaged drywall in the area where the backsplash will go (above the countertop & below the upper cabinets.
One section of the wall is brick with some kind of painted cement over it.
The part that will be behind the drywall was all cracked right down to the brick, so we used some rough-grained parging cement to fill it in and bring it up to close to the same level as the part that is smooth.
I now need to put a smooth layer over top that we can apply thinset and the tiles on top of.
Any recommendations on what would be best to use ?
I have been told not to use spackle, as it won't be strong enough to hold the tiles. Am unsure on whether I can use thinset to level the surface and then apply another layer thinset on top when it comes time to do the backsplash tiling (at least a few days later, long after the smoothing layer has cured).
Any help greatly appreciated.
Thanks. Patrick.
Top
#17574 - 02/10/12 08:17 AM Re: Tile backsplash over brick/concrete [Re: pmacaula]
RC Offline
Senior Member
Loc: Ontario, Canada
Your right, do not use any drywall compounds for filling the wall.
If you could post a photo of the area in question that would be more helpful in evaluating the repair area.
Without seeing it I would suggest using a modified thinset and stucco mesh to skim the area.
When you get it flat (by skim coating) you can install the tile. There's no other prep work needed.
_________________________
Randall
Top
#17575 - 02/10/12 11:26 AM Re: Tile backsplash over brick/concrete [Re: RC]
pmacaula Offline
New Member
Loc: Toronto
Randall,
Thanks very much. A photo of the wall as it is right now at this link - Kitchen Wall photo
You can see the bare brick near the floor and the part where I have layered on some parging. I want to create a smooth surface level with the painted area before the kitchen cabinets go in so that the tiling will be that much easier when I get to that point (have to wait for countertop, etc).
Thanks. Patrick.
Top
#17576 - 02/10/12 05:10 PM Re: Tile backsplash over brick/concrete [Re: pmacaula]
RC Offline
Senior Member
As I mentioned before, skim coat the parging with thinset to get it flat. Tape the inside corners with an alkali-resistant mesh tape and coat it with the same thinset.
Randall
Top
#17578 - 02/13/12 09:06 AM Re: Tile backsplash over brick/concrete [Re: RC]
pmacaula Offline
New Member
Loc: Toronto
Randall - thanks again. Have the modified thinset and the mesh tape. Will get at it as soon as the refinished floor is dried (and covered with hardboard).
Cheers. Patrick.
Top
#17640 - 02/29/12 06:43 PM Re: Tile backsplash over brick/concrete [Re: pmacaula]
pmacaula Offline
New Member
Loc: Toronto
A quick update - here is the current state of the wall. Nice flat thinset ready for tiles ! Waiting for the countertop ...
Kitchen Reno - stage 2
Top
May
Su M Tu W Th F Sa
1 2 3 4 5
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30 31
Newest Members
jimysakura, yes123, Curt, joke, keys
3464 Registered Users
(Views)Popular Topics
Where do I begin... 61443
Kerdi Board 39849
Installing Nu Heat on Cement Slab 26105
Kerdi over Denshield 21029
Help with preslope!! 20779
Self-leveling compound on plywood 18582
slate tile on heated floor 16252
best liquid waterproofing? 14998
Ted's Shower 14268
New here, new to tile, and i have a new project. 13975
Forum Stats
3464 Members
16 Forums
3502 Topics
Max Online: 556 @ 05/14/12 10:04 PM
Who's Online
2 registered (RandyL, eliav), 318 Guests and 4 Spiders online.
Key: Admin, Global Mod, Mod
RSS Feed
Subscribe to our RSS Feed
Home    Forum     Technical Info     Our Service     Photo Gallery     Installation    Contact Us    Privacy     Links    Books
